Brian wrote:I do not think Roadless used the dual clutch, at least I cannot remember one. The ones we serviced had HD 11" or 13" clutches, some had sintered bronze lobed discs like the County range.
I work for an ex Roadless demonstrator repairing electronics, next time he phones me I will ask.
The live clutch was designed for a Major at 40hp, it would have normally had a 30% overload factor built in, The hp of the Power and Super reduced this.
Clutch heating became a problem and cracking in the aluminum housing caused us to change many of them.
There is no practical way of strengthening the clutch.
en
This is interesting.
 For some time I have followed this thread and discussed the matter with a former colleague that is very knowledgeable when it comes to Fordsons and owns several types. He told me, that the reason live clutches fail when used in combination with 6 cilinder engines is the
 higher rpm rather than the
power transmitted. Centrifugal forces / unbalance will cause the spectacular type of damage discussed in previous posts. He confirmed Pascal's remark that the max rpm on the 590e engines was limited, causing it to deliver no more than approximately 80 hp. Using a six cilinder engine on a live drive tractor would be no problem if you use it  with common sense and run no more than 2200 rpm. Brian, what do you think about this
Also, he was sure Roadless had delivered a 6/4 Ploughmaster with live clutch. Yes, I really do want one
And ehhh..... a happy and healthy 2011 for all
