Any views?
I am about to attach the timing case backing plate and was unsure if there should be sealant of any form on the gasket (e.g. the orrible Hylomar?)?
Mark
Sealant on engine gaskets?
Re: Sealant on engine gaskets?
I have some of this stuff:
http://www.heldite.com/html/technical_info.html
Which I think should be ok.
Hi Mark.
I have done on all of my gaskets excluding the head gasket that is!
Just an extra precaution, just not too much though.
Regards,
Regards,
Mark
Thanks Mark
I use the Heldite (which is thin and paints on) on the locomotive and DMU and just wondered on peoples thoughts.
So sealant it is!
So sealant it is!
