Here's a little update from me.
It was pretty easy to get the seals, gaskets, drive shaft and bevel gear...the bearings were a complete different story..
It doesn't really helps when they send me the wrong size, although I had given them the old ones to compare..
After 3 weeks I finally got all the bearings I need so far!
I hope to start working on the gearbox on Thursday. First thing to do is to put the most rear gearbox-axle in and than mount
the gearbox housing.
Some bearings consist of two or three parts (inner ring, cylinders and outter ring). On one side of the bearing cage there's a
bigger ring (to hold the smaller cylinders within the bearing) than on the other side. Does it matter on which side I mount then?
Any other advises when mounting bearings? It's the first time for me.
