Hello,
just looking for some info about diesel filters for 1956 major diesel, the normal filter that seems to be supplied for most majors does not fit. this tractor is fitted with a filter that is longer and has a bigger diameter hole in the ends, the filter housing has FRAM stamped on it but i cant see a part No, the filter is approx 90mm long it has a 66mm diameter through the main body of the filter and at the end caps it approx 74mm, the diameter of the hole is 30mm, any idea of a part no or where i can purchase one would be much appreciated.
many thanks
Stuart
diesel filter for Fordson Major Diesel
YCJ357-SMD
Re: diesel filter for Fordson Major Diesel
Stuart,
A pictures could help us a lot.
Hi Stuart,
The Fuel Filter Element to suit a FRAM Head (1952-1954) is Part No. E1ADDN 99162A.
Elements suitable are:- Ford AFL126, Ryco R2003P, Crosland 452.
BarryM
YCJ357-SMD
Thanks for the information,
I have a photo but not sure how to upload it, can some one tell me how it's done.
Stuart
Stuart
