Hydraulic Adjustment
marcusgs
Post by marcusgs »
I'm having trouble adjusting my hydraulics. I've taken the top cover off about 8 times now and I refuse to do it any more until I know exactly what i'm doing!
I've just stolen the picture below from someone else's post on the forum (many thanks to whoever it was, hope you don't mind!)
I've been reading that the reason most people can't adjust properly is because of a worn pin somewhere, but I can't work out which one it is from the description and the photo in the previous post
Can anyone clarify please?
Mark
Mark
Tubal Cain
Site Expert Team
Site Expert Team
Re: Hydraulic Adjustment
Post by Tubal Cain »
Looking at the photograph you can just see the end of the pin just above the edge of the cover below the diagonal lever.
The pin acts on the cam which you can just see in the lower right of the photo. To renew it you really need to strip the cover down.
The replacement pin is 0.309" in dia x 7/8" long.
Gerald
Mervyn Spencer
Post by Mervyn Spencer »
Hi Guys
Both of you are stars, :clap: Mark for putting up the picture andGerald for the dimensions. My top is currently with the New Holland repair shop and I was chatting to them about that same pin, but did not know where it was. Now I know thanks again.
Mervyn
marcusgs
Post by marcusgs »
Hi Gerald,
Thanks for that.
I'm 99% sure you mean the one in the green circle :D
Mark
Mark
tom lad
Post by tom lad »
correct mate :beer:
cfp cam follower pin
i slapped some grease on the area on re assemberly not sure it helped but made me feel good :buddies:
mine was off loads of times too , heavy aint it .
tom
Tubal Cain
Site Expert Team
Site Expert Team
Spot on.
Gerald
marcusgs
Post by marcusgs »
Hi. Thanks everyone!
Yes it's a beast, luckily I have it suspended from my overhead winch which makes life easier!
Mark
Mark
tom lad
Post by tom lad »
i put a bolt / chain in one of the threaded holes for the seat , and block un tackle above .
to heavy to man draulic i tink
did it by hand first time but thats a bit stupid tbh
to many things to brake .
