I am replacing the hydraulic pump on my super and want to change the hydraulic return filter. I have the pipe and filter off, am I right in thinking you just undo the pressure valve body to remove the filter?
It seems very tight?
Hydraulic oil filter
Re: Hydraulic oil filter
That's what it says in Section 6 of my Super Major Supplement Manual "Unscrew the back pressure valve from the exhaust oil pipe". I cannot recall it being stupidly tight when I did it on my NP Super Major...Good luck.
Thanks mate. Got myself that supplement today. Got filter changed but it was very tight.
job done thanks!
job done thanks!
