steel radiator cowel
anyone know were u could find a steel cowel for a dexta 1958
thanks
thanks
Re: steel radiator cowel
Keep looking on ebay,DEXTAS wrote:anyone know were u could find a steel cowel for a dexta 1958
there's one there now, 230795502964
It will fit fine, but strictly not quite correct for a 58 Dexta (a small difference behind the light mounting holes), so depends how rigourous you want to be, even your side of the water.
not a nose cone ben a radiator cowel am looking for but thanks
Ah Ha, they hardly ever come up on ebay. I'm repairing mine despite it looking like lace. Expect you're aware of the fibreglass rad cowels, maybe they are OK?DEXTAS wrote:not a nose cone ben a radiator cowel am looking for but thanks
they would do the job but im really trying to keep it as origonal as possiable
Have you tried the usual breakers?DEXTAS wrote:they would do the job but im really trying to keep it as origonal as possiable
have seen a few but beyond repair
Get one and use it as a pattern. Any decent panel beater/welder should be able to make/repair even a poor one, as the metal is no thicker than a car body panel and the shape less complex than say a car wing.DEXTAS wrote:have seen a few but beyond repair
A few months ago i got a new steel fan shroud/radiator cowl from forge services....it fitted alright although i had to make the drilled holes slotted to make it fit.
Hope this helps.
Hope this helps.
how much was youres
It was around 100 quid....pretty pricey but i didnt fancy having a plastic one in its place.
could u get me the number or website for them mate thanks
Re: steel radiator cowl
http://www.forge-services.co.uk/acatalog/BonnetDex.htmlDEXTAS wrote:could u get me the number or website for them mate thanks
Suggest you contact Peter Smith at Forge Services via the website. Peter is both knowledgeable and helpful.
I agree with Ben...Peter is a very pleasant guy to deal with and he knows his stuff.
thnks for the help al give him a buzz
