What is the correct starting procedure for a fordson n, guessing it would say in a manual if someone happens to have one.
Buster
Propper way of starting.
Aussie Frank
Re: Propper way of starting.
Hi Buster.
The starting procedure should be close to the E27N starting procedure. There is a copy on this site http://www.fordsontractorpages.nl/manua ... _guide.htm I don't know why it says new major, but if it is the same as my E27N manual you should find the starting procedure on page 21. The files are fairly large so I have not had time to download the manual to check it but give it a go hopefully I am right about the page number.
Regards, Frank.
Regards, Frank.
