My 5000 turns sharper to the left than the right.
It's had a 2nd hand power steering system added to it (not by me). It's the type that has the power steering ram under the radiator.
The draglink from the steering box arm to the front axle spindle arm appears to be too short. I may have to cut & weld to check it out.
Doe's anybody know if the PS 5000 used the same length draglink as the non PS 5000.
My draglink measures 1250mm ctr to ctr of the balljoints, the same length as my non PS 5000.
I look forward to any replies.
Kiwi Kev
