Drop arm
Drop arm
My adjustable drop arm was stuck so after a liberal amount of oil and grease I tried to force it free. Of course the only result was that the lever now moves around very easily and nothing moves up and down. I found a replacement at agriline (4008 Drop Arm - Adjustable) but it looks very different (for starters no handle to break the internals with). Is this the right part? Is this a standard tractor part and might I dig up one locally and save me a lot of shipping cost?
Re: Drop arm
what you are requiring is a levelling box part 4003 from Ag.... this has the shaft and the box with the gearing and adjusting handle
Re: Drop arm
Thanks!Brian Cox wrote:what you are requiring is a levelling box part 4003 from Ag.... this has the shaft and the box with the gearing and adjusting handle
