hi , this is my second post about the littel dexta
sometimes the lift arms wont raise when i raise the controls,
they only lift when i take off in gear and move the tractor. when its idle it wont raise.
what could be causing this
also when i have the tractor on a rotavator, a 4ft howard. the pto keeps jumping out of gear when it hits any hard spots.
i have to hold it back with my hand but wit eventually jumps out again when it hits hard ground.
where is the inspection plate on the tractor to see the workings of the pto selector.
any help on either of the two would be brilliant.
slow lift arms
slow lift arms
Is Mise Mochara
Re: slow lift arms
hi Mochara, are you moving control right to the end of travel ? Also try a wee bit more revs. of the engine
Re: slow lift arms
ah ye i am doing that alright brian , all the way up to the top , bit more revs doesnt do anything , its only when i start releasing the clutch to move it and it comes all the way up then pretty fast;
i am more concerned about the pto , did you have a look about that for me ,
it keeps jumping out of gear with the rotavator every time it hits hard ground.
Is Mise Mochara
Re: slow lift arms
Hi Mochara, I dont think you should have your foot on the clutch anyway, sorry I have the same prob with pto and i'm awaiting replies myself on ideas to resolve it
Re: slow lift arms
Hi Mochara, hopefully Brian [grumpy] will pick this up as he is an expert on these problems
Les bryant
Re: slow lift arms
If your tractor is non live drive the hyd. wont lift with your foot on clutch peddle.
Regards Les.
Regards Les.
Re: slow lift arms
cheers lads, thats the lift arms question answered , the pto is a big one though.
anyone any update on what may be the cause or have the fix for it.
Is Mise Mochara
Re: slow lift arms
Is Mise Mochara
