Does anyone know if a Dexta Live clutch assembly can be fitted onto a single clutch flywheel?
Thanks,
									Dexta Live Clutch
				marcusgs
Dexta Live Clutch
Mark
						Re: Dexta Live Clutch
Flywheel is the same.  Yes.  However the transmission is different.  To attain Live PTO, you will need dual clutch assy and live transmission.
Wayne
									Wayne
				marcusgs
Hi Wayne, I have managed to get a live gearbox, I just need to source a dual clutch assembly now.
Is everything rearward of the gearbox the same? I.E. trumpets, back end.
Thanks,
Thanks,
Mark
Do both have diff lock?
