Major Grease Nipples
Bensdexta
Post by Bensdexta »
What size are the nipples on Majors? Are they all 'push-fit'?
It seems that dextas have 1/4" UNF threaded nipples, so not the same as for Majors??
TIA :wink:
Bensdexta
Re: Major Grease Nipples
Post by Bensdexta »
Does any one use these 1/4" UNF nipples on the Major?
http://www.malpasonline.co.uk/itm/Imper ... wIqCx.dpbs
TIA
Ben,
As afr as I know all nipples on the Major are 'push-fit', size 5/16. But 8 mm wil work also.
Bensdexta
Post by Bensdexta »
Will the same grease gun cope with most sizes of nipple, 1/4", 5/16", 8mm etc..?
Yes
