Hydraulic pump
Hydraulic pump
At the end of the summer the hydraulic pump gave some trouble. Because I have to renew the rear axle seal and remove the rear end cover, I could check it out. When I opened the pump I found the O-ring around the relief valve broken.(see red arrow) This was the same when I rebuild the pump about 7 years ago. Then it was also broken on the exact same place.
(see red arrow) Is this a common thing or is something wrong.
Re: Hydraulic pump
No one ever had this problem?
Major Mike
Re: Hydraulic pump
Post by Major Mike »
Yes, worn pump. Too much axial clearance, or do you say, end play is too big. You have to grind or sand down the pump body. :D
hopefully you understand my bad language.... :lol:
Another way is to do shim plates, behind the bearing cups.
Super Major -62, Super Major 6 Cargo ~130 hp, ford 4550 & Haka, Ford 6600 backhoe, Valtra 6400
Re: Hydraulic pump
Thank you Mike.
You are right I think. The bearing are 0,5 mm lower than the surface. I will make two shims from 0,5 mm.
Re: Hydraulic pump
Thank you Mike.
