Dexta hasn't been used for quite a while now. Im just coming to the close of the Ferguson FE35 23c engine rebuild, and have a few niggly issues i'm working through.
During this, I fitted a new glow plug/fuel valve thing to the manifold. Tried it yesterday for the first time as tractor was ready to start. I love how simple yet effective this is! Once the plug glows red, it opens the valve and lets fuel in, and ignites! If the ignition is turned the right way, the plug remains glowing and igniting fuel and the engine sucks this in. I have the fuel pump timing slightly out but once this is fixed im sure it'll fire right up
Got me thinking, someone in the past has drilled the top of my dexta manifold and fitted one of these as an addition. I may modify the cold start system to allow a free run of fuel to this plug, and see how it works. May fit a fuel tap jest before to allow manual fuel shutoff in the event of valve failure..oooooooo ideas ideas
