As I have mentioned before I don't like the clutch pedal when it's in stage two for engaging the PTO. It rides way to high.
But I do need to have it set up this way, so I can start and stop the snowblower. I thought I play around with a override system
with a handle to make starting and stopping the PTO a bit more easy.
Do you think this will work?
									Tom T. Winchester
Little did I know that all those days passing was life itself!
