Hello everyone.
I recently bought a super dexta, unsure of the year bit what I've found is they were produced 1962-1964 (correct me if I'm wrong). Any pointers/tips on these tractors will be appreciated.
Thank you.
						my first super dexta.
Re: my first super dexta.
Thank you. I found a engine cast # by the fuel pump and exhaust manifold. 957E 7005. Haven't found any engine codes that fit that. Finding photos of my tractor online shows that it's a 62-64.
Engine no is front LH side of engine just below the head. Supers start 16...cattleguy wrote:Thank you. I found a engine cast # by the fuel pump and exhaust manifold. 957E 7005. Haven't found any engine codes that fit that. Finding photos of my tractor online shows that it's a 62-64.
See sticky top of Dexta forum for engine cast codes.
.Bensdexta wrote:Engine no is front LH side of engine just below the head. Supers start 16...cattleguy wrote:Thank you. I found a engine cast # by the fuel pump and exhaust manifold. 957E 7005. Haven't found any engine codes that fit that. Finding photos of my tractor online shows that it's a 62-64.
Thank you for the tip. Found the # under some engine grease. 1607927 looking around casually on the interwebs
Puts your Super Dexta (engine!) about Aug 1962.Tractor # and casts codes would confirm.cattleguy wrote:Engine#... 1607927
