Just changed the king pin bushes and bearings, 1 wheel bearing kit and the tie rod pins and bushes on my 1955 FMD, and I can now drive in top gear on the road without the dreaded steering wobble.
 Now I am a little concerned about the lack of power in top gear. I would have thought it should pull well up an incline in top gear without the power dropping off and a bit of smoke and having to change down. I have given it a good service, including new fuel filter housing and filter, new air inlet pipe and a good clean of the air filter and fresh oil etc.
The injection pump timing is spot on to the manual. The other thing I noticed while road testing is a slow uptake of power in top, i.e. it seems to pick up very slowly, almost as if the governor is having trouble moving the injection pump rack.
So, do you reckon it is time for an injection pump test and overhaul the injectors? Knowing the tractors history, I would be suprised if it has had any maintainance in that department in the last 30 years.
Look forwar to hearing what you all think.
Regards Huzey.
