Haha, I knew the orange paint would get people talking!
  Sadly, I don't have any history on it. I found it on craigslist among an ad for "old tractors for sale". The man I bought it from said he had bought about eight years prior with the intention of restoring it and just never got around to it. It was blue at one time, as I found some traces of blue on the inside of the side rails. So I guess that means its not a "one off" special. Now, as promised, more pictures!
55 years of built up gunk on the oil pickup!
Original main bearings
Crankshaft
Each one of the rod journals has a very slight groove that I can just feel with my fingernail, I don't think its bad enough to need machining but am open to suggestions...
Also, there are marks on the number two main journal as seen in the second picture, but I can't feel any change in the surface with my fingernail. What do you guys think?
All of the bearings are std size and original Enfo bearings.
Camshaft
I know these engines did not have replaceable cam bearings, so I hope it will be alright as is.
Now for the ugly part... the number three piston was pretty boogered up around the periphery of the piston top with some of the material burnt or wore off. I found it stuck to the side of the liner:
I had a hard time getting the piston out, which naturally scored up the sides of it on the way out...
Number two was not as bad, but still damaged as well:
I didn't take any pics of the pistons yet.
And I will end it tonight with a question regarding these pictures:
I know these are locating dowels for the head gasket, but how critical are they? I don't remember there being any on my 1956 Major, and these are pretty rough looking. Can they be removed easily or should I just not worry about them?
