half shaft seals
sky blue
half shaft seals
Post by sky blue »
a :?: about h/shaft seals, is the easy one to do
the inner seal or outter seal i
have seen this seal called both :scratchhe
can confuse us lesser mortals
also is the te20 an s/dexta the same :oops:
sky blue
Re: half shaft seals
Post by sky blue »
the first you come across is the inner seal this is the smaller of the two
the one behind the berning is the outter seal it is a lot bigger and alot more work
to renew, the te20 inner seal does fit the dexta if one was unable to get the right
one , the outter seal needs a dexta seal :clap:
