Front hubs
				woodcutter
Front hubs
Hi all I've got a diesel major with cast front wheels, if I want to change to steel wheels will the front hubs from a later major fit my axle/spindles or is there more to it than that? Cheers any advice appreciated
				oehrick
Re: Front hubs
I think so as ISTR using one after a shredding the tyre on a cast hub.
If no one else can confirm I'll measure the pair of tin wheel bores up when I go over to the tractor later in the week (I've a pair that remained when the Super departed for another life) The (bald) tyres are much wider than the ones on the cast hubs and are not nice without power steering.
				woodcutter
Re: Front hubs
Ok cheers my tyres are worn and I know of a pair of front hubs and wheels off a super major and I prefer the lighter steel wheels
						Re: Front hubs
They are all the same ,Liam
				woodcutter
Re: Front hubs
Ok cheers do you use the same nut that holds wheel on to hold hub cheers
				blackbob
Re: Front hubs
Yes. I've done the swap too.woodcutter wrote: do you use the same nut that holds wheel on to hold hub cheers
1440276 - 1957 - working
1335674 - err - one day..
Ford 7710 2wd, 1983 - working
