1/ Ive fitted the yellow wire from the solenoid and yellow wire from A on control box to battery on ignition switch as per wiring diagram.
2/ The yellow/white wire from generator warning lamp ive joined with the yellow/white generator wire at terminal D on the control box rather than at the generator end.
3/ Ive put the brown wire that feeds the manifold heater switch on to the coil terminal at the ignition switch as this feed is live when the switch is on.
4/ Generator output and wiring checked at the control box end as per workshop manual and is reading 14.5v when the manual says it should rise rapidly to above 24v. Wiring haas been checked and is okay. Fault with generator??
5/ Open circuit voltage test as per workshop manual is reading 16.5v.
6/ The Amp output test as per workshop manual is only showing 0.4 amps before connecting and once connected does not increase but stays at 0.4amps.
My question is, are the points welded together or is the control box requiring adjusting. I didnt want to start turning adjuster screws in case I damaged something. If it requires adjusting which screw is it as the control box is a sealed unit.
The generator lamp is bright on start up and goes out when revs are increased. Checking voltage across the battery it is showing 12.7v at full revs. Should this not be higher?? Do I have various faults i.e generator and control box or is it all control box??
Appreciate any advise as my electrical skills are basic, give me spanners any day lol.
