Thanks,
Ben
Rick,Meanderer wrote:The tool is called a Wad Punch. It's good to have a set of them. Pretty cheap to buy. When using the wad punch on a block of wood, use the end grain of the block. Best if you put your block of wood upright in a vice. The end grain affords better penetration and a cleaner cut to the material your cutting and preserves the cutting edge as well.
Henk/Rick,henk wrote:This is what I wanted to say but did not know how to explain it. Manny Thanks.
The second way of doing the job have to be done in a careful way. If you do it wrong you can damage the surface.
COINCIDENCE! I've just come back from going to my young cousins farm about 20km away. He was putting eyelets into a tarp. It was a really cheap and nasty eyelet kit he'd bought. I saw that there were a few rings cut into the side of a block of wood. I asked what caused them. His reply, The little punch (tubular wad punch) that you use to put a hole in the fabric. I told him he'd be better off using the end of the wood and why. He replied that after those 3 holes he had to use the grinder to sharpen it again. Now using the end of the wood, he did another 25 holes and the punch is almost as sharp as it started out.Meanderer wrote:When using the wad punch on a block of wood, use the end grain of the block. Best if you put your block of wood upright in a vice. The end grain affords better penetration and a cleaner cut to the material your cutting and preserves the cutting edge as well.
