Super Major Handbrake
				CraigScania
Does anyone know where in the UK i can get the two pins for the handbrake pack on the Major? I have got the brake plates from Agricar but they cant get the pins. Craig
				CraigScania
				BearCreek Majors
As I understand it, in the UK the DOT (Department Of Transportation in the US…have no idea if that’s what it’s called in the UK) requires the tractors to have a tag (license plate) tail, marker, and head lights, as well as a hand brake.  As these options were not required in the US most of these items were not installed presumably as a cost savings, not to mention that if you don’t like the way I drive stay off the sidewalk!!!
Pat
 Pat
We had a few Drunkin hired hands that would drive around with the brakes locked on no matter what it was that they were driving.   Use to drive my dad nuts.
 Use to drive my dad nuts.   Nowadays you don't dare hire a drinking man and put him on a machine, or behind the wheel of anything. About the too dumb part, it was not true of owners, but hired farm help....
 Nowadays you don't dare hire a drinking man and put him on a machine, or behind the wheel of anything. About the too dumb part, it was not true of owners, but hired farm help....  Dandy Dave!
  Dandy Dave!
  Dandy Dave!Have a Fordsonful day Folks!
The problem we used to get was not driving with the brake on, because if you had the brake on fully it would stall the engine or not let you put the tractor in gear, it was driving with the handbrake just on! So on all new tractors, we used to remove the handbrake ratchet and grind the first three or four teeth off. So the brake was either on or off.
Worked well and stopped that problem but the one you could not control was people using it to stop when the tractor brakes were out of adjustment. That would nicely bend the pins and crack the gearbox housings.
