Chassisnumber Fordson Dexta
				jozefvanni
I have a Fordson Dexta restored and I would want to inscribe the tractor.I have no papers of this tractor and chassis number is partially unreadable.Only 957E are readable and the rest of the number not.My question now is if you can help me to find a other chassis  number .Jozef Van Nieuwenhove from Belgium.E-mail: *********@******.**.
Reason: Removed emailadress for security reason. Members can help Jozef by replying to the topic or can contact him through the board message system
Re: Chassisnumber Fordson Dexta
Welcome Jozef.
I see you have followed my advice to join here. Hope someone can help you.
Better remove your emailadres. Readers can contact you through the adres of the forum.
Hello Jozef,
Welcome to the board.
Are you looking near the clutch flange?
See also: http://www.fordsontractorpages.nl/phpbb ... hp?p=45807
Maybe you can use the steel wire brush and then it can become more visible.
The casting number can also help to determine the year it was built. I've once seen paperwork done by New Holland where they used a casting number.
				jozefvanni
Hallo,
The serial number on the flens is 957E .......and the next is not readable.
The other numbers are: motornumber: 1493060
K14I
G0280098
2GKN1372
clutch housing;K29F
957E7505C
gearbox:957E7005
K24F
lift cover:957E4024
L15F
rear end:left axle:L14F
right axle: J14F
K14I
G0280098
2GKN1372
clutch housing;K29F
957E7505C
gearbox:957E7005
K24F
lift cover:957E4024
L15F
right axle: J14F
