Dexta throttle linkage broke
Have a problem on my dexta. The throttle linkage from the intake butterfly to the side lever broke and I can’t seem to find it anywhere online or anything. Any help is appreciated.
Re: Dexta throttle linkage broke
here is a picture of the linkage part i am needing. Hopefully this will help someone tell me what this is called and where i can get it from. Thanks again! (will have to open image in new tab possibly to get it to work correctly.
This one?
Ebay uk.Item no 323157602914.
He has lots of Dexta parts.
Old Hywel wrote:This one?
It is kinda like that except it has the spring loaded catch that goes
Over the ball linkage on both ends and you adjust the linkage in the middle as it is both ends threaded, if that makes sense
MikesDexta
I think that is the part you need, the spring loaded bit is shown in the 2nd picture but i'd be a tad worried it wouldn't clean up and the spring may not work as it looks pretty pitted to me? Scrappies are certainly your best bet, I met one at Patrick Edwards' Tractor Jumble last Saturday who seemed a helpful bloke, he's looking for a RH Lift Arm for me. His name is Stuart Moores, S&K Machinery 07977 605043.
good luck
Mike
good luck
Mike
1959 Dexta
MikesDexta
1959 Dexta
Tubal Cain
- Site Expert Team
Quality Tractor Parts stock a variety of throttle linkages similar to what you require. Unfortunately they are wholesale only so you have to find a dealer who stocks or can obtain parts from them.
Their catalogues can be viewed on their Website at https://www.qtponline.com/en/catalogues.html.
Gerald
Gerald
