Fordson major narrow front end
dromonedog
Recently acquired a narrow front ent for a major and was wondering if the upper housing should be filled with oil to lubricate the two gears in there or maybe use a heavy grease. There is no level plug for this housing but there is a 1/4 pipe plug on the vertical housing and it was filled up to this plug with oil.
Re: Fordson major narrow front end
dromonedog
Not sure how to load photos
Heydromonedog wrote:Not sure how to load photos
You can use postimage.org or similar.
