Fordson Super Major dozer implement
Fordsun
Post by Fordsun »
Hi Everyone, I have just purchased a dozer blade assembly it is the type that has a ram underneath, it was put out here in Australia by Ford under the name Blue Line, they were made by Napier, mine has the ram missing and I have not placed the assembly on yet ,however can anyone advise the correct ram for it as ie size, Diameter, shaft diam, lenght closed lenght open ,https://www.fordsontractorpages. Regards John.
Re: Fordson Super Major dozer implement
I don't know if that's the right blade, but see what you think, you might want to consider using an auxiliary valve chest to operate it.
https://www.youtube.com/watch?v=dF8CKY0 ... ndFordsons
Some pics might help others give you ideas (I can't any more than this because I don't know much about dozer blades).
Boggy1
Post by Boggy1 »
Hi John. I am in Queensland and have the same set up on my FSM. If you still need measurements I am happy to measure mine up for you. It's been a while so you may already have it sorted but the offer is there if you need.
Old tractors,trucks and amateur radio
