Injector pump numbers
Thought it would be good to list all numbers we know, and add any that appear or I've missed.
SPE 4A 70S 296 E1ADDN-993100 Major diesel, vertical
SPE 4A 70S 352 954E-993101 GV governor, EFA15 excess fuel
SPE 4A 70S 368 Major diesel, inclined, 45 degree helix, GPD90A19 governor
SPE 4A 70S 371 E1ADDN-993101 With exhauster, normally lorry parts, GPD90A35 governor (red spring)
SPE 4A 70S 380 E1ADDN-993100B Major diesel, 50 degree helix, EFA14 excess fuel, GPD90A19 governor, GPD90A39 governor from pump 176929 (blue spring)
SPE 4A 75S 497 530E-993101 With exhauster, normally lorry parts, GPD90A39 governor (blue spring)
SPE 4A 75S 498 E1ADDN-993100C Major Mk2, GPD90A39 governor (blue spring)
SPE 4A 75S 500
SPE 6A 75S 318 510E-993101 With exhauster, normally lorry parts, GPD9039 governor (blue spring)
SPE 6A 75S 320 590E-993101 GM governor, EFA15 excess fuel
SPE 4A 75S 513 E1ADDN-993100D Power Major, GPD90A39 governor (blue spring)
SPE 4A 75S 515 954E-993101B GM governor, EFA15 excess fuel
SPE 4A 75S 527 E1ADDN-993100E Power Major, tractor parts, forward bleed screw, GPD90A39 governor (blue spring)
SPE 4A 75S 561 S1ADDN-993100E Ebro Diesel, tractor parts, forward bleed screw, GPD90A39 governor (blue spring)
SPE 4A 75S 646 S1ADDN-993100F Ebro Diesel, tractor parts, 7 degree damping valve (GPD90A70 governor) (blue spring)
SPE 4A 75S 647 E1ADDN-993100F Power and Super Major, tractor parts, 7 degree damping valve (GPD90A70 governor) (blue spring)
SPE 4A 75S 683 E1ADDN-993101D GM governor, tractor parts, EFA16 excess fuel
P4596 E1ADDN-993100H Super Major, tractor parts, blue spring
P4595 530E-993101C/D With exhauster or separate bracket, normally lorry parts, white spring (C with 510E-9350, D with 530E-9350, only change is position of valve body E1ADDN-9353)
P4590
P4598
P4630/A Ebro 160, tractor parts
