In order to do rings/big end bearings does anyone know if it is necessary to split the tractor or can the sump be removed safely. I fear the sump may be structural
Rob
Do you have to split?
Tubal Cain
- Site Expert Team
If you are going to do mains and big ends it is shortsighted not to have the crank re-ground too. If you need one you need the other on these engines.
This would mean complete engine removal which is the easiest way.
