It seams that the axle seals on my dexta need to be replaced...and the brakes renewed.
Can anyone provide step-by-step best practice for this job...
I am not familiar with Dexta internals yet but will be after this...
Many thanks as always.
Miles
Replacing axle seals 101
Tubal Cain
- Site Expert Team
It all depends on the age of your tractor! The earlier tractors used a steel collar shrunk onto the shaft to retain the bearing, later models used a nyloc nut 2.3/4" or 70 mm AF.
Rather than try to provide a step by step guide I suggest that you refer to the workshop manual, then if you have any queries or hit a problem you can call on members of the forum for help.
Gerald
Gerald
By way of encouragement - I'm new to Dexta's but by using the workshop manual and searching in this forum I was able to remove and replace the axles easily. Mine had shrunk on collars so I got a local engineer to replace them.
I would also mention that the best method to set the end float is to use a dial gauge with a magnetic base rather than the feeler gauge method described in the manual.
Andy
Andy
Tubal Cain
- Site Expert Team
Bearing in mind that you intend to use the tractor on your land and
without turning this job into a mammoth exercise, if you intend to drain the oil it would pay you to lift the top cover with the hydraulics. This will then enable you to clean out the gunge which invariably collects in the axle casing and will also enable you to inspect and clean or renew the suction and return filters for the hydraulics. The return filter is a paper element type and is available form New Holland dealers Pt. No. 81800792 (E68-GF-9)
Whilst the cover is off you can also inspect the linkages and pins for the hydraulic lift.
Gerald
Gerald
