Should I coat new gaskets for the water pump & thermostat housing with a bit of sealer before I bolt them up? Or is the gasket by itself enough?
TIA
Gasket Sealer?
Gasket Sealer?
Re: Gasket Sealer?
yes, definitely use gasket sealer as you do not want a water leak in future. it would mean redoing the job once again
Re: Gasket Sealer?
id use a non setting one , blue hylamar , works for me .
