Starter Motor
damian green
Starter Motor
Post by damian green »
How do I disengage my starter motor...... when the battery is connected it turns over even when the engine is running. At the moment I am taking the live lead off once she starts, but this is not a fix. Any ideas or images would be great.
Thank you in advance.
Kind regards
Damian
Dunggatherer
Post by Dunggatherer »
Good day Damian,
If everything is still connected as original,it seems your starter relay is stuck.
You should find it near the batterytray.
I don't think there's a fix for this,just replace it.
Good luck.
Rob.
Mervyn Spencer
Post by Mervyn Spencer »
Rob, I take it you are referring to the solenoid :?: I would have thought the exact same thing.
Dunggatherer
Mervyn i stand corrected.
That's what i meant,too much wrenching on cars lately...
Mervyn Spencer
Hi Rob, just as a matter of interest, what is a solenoid called in Dutch?
woodseaves
Post by woodseaves »
Acording to Google!!!!
solenoïde
Mervyn Spencer
Thanks Woodseaves.
damian green
Starter Motor
As always many thanks for your quick replies, I will get one and get back to you with my findings.
Damian
YorkshireDextaMan
Post by YorkshireDextaMan »
It could be the switch on the starter it's self thats sticking . pull the rubber shroud back and give it a squirt of WD40.
You could also try tapping the solenoid , Jim
russelm
Post by russelm »
Yes, do some basic continuity tests on the starter solenoid and starter motor switch to pin point the fault first.
dexta61
Post by dexta61 »
A solenoid is in Dutch "start relay"
I just bought a DEXTA
dexta61
Post by dexta61 »
Dunggatherer
Yep that's the most commonly used word for it.
If i would go to a tractor dealer and ask for a solenoid i would probably just get empty stares,asking for a starter relay they will reply "here you go,anything else?"
The word "solenoid" is more used in cars, for instance the stepper motor that regulates the idle speed by varying air inlet.
Or in model planes to drive the throttle and wingflaps.
