Starter Motor
damian green
Starter Motor
How do I disengage my starter motor...... when the battery is connected it turns over even when the engine is running. At the moment I am taking the live lead off once she starts, but this is not a fix. Any ideas or images would be great.
Thank you in advance.
Kind regards
Damian
Kind regards
Damian
Dunggatherer
Mervyn Spencer
Dunggatherer
Mervyn Spencer
woodseaves
Mervyn Spencer
damian green
Starter Motor
As always many thanks for your quick replies, I will get one and get back to you with my findings.
Damian
Damian
YorkshireDextaMan
Dunggatherer
Yep that's the most commonly used word for it.
If i would go to a tractor dealer and ask for a solenoid i would probably just get empty stares,asking for a starter relay they will reply "here you go,anything else?"
The word "solenoid" is more used in cars, for instance the stepper motor that regulates the idle speed by varying air inlet.
Or in model planes to drive the throttle and wingflaps.
