Super Major - DAR fitment
Roadless63
Post by Roadless63 »
Agree Brian, I have never heard/seen this set up either, for a Super Major installation. Cant have been very popular, perhaps DAR for super major was developed as an improvement?
Foxen
Post by Foxen »
Brian wrote:Yes, I would agree with your comments but the porting layout is for a FMD or Power Major.
I think I see the answer, there is a plate, E285WP9 that blanks off the valve porting for the FMD/Power Major, and the valve system is fed from the Super auxillary chest via pipe E288WP9 return to tank is via E90WP9 into the filler cap.
It looks like Ford was using up old Power Major parts on the later tractor. It is only single acting on both levers though.
You learn something new every day on this site. I have never seen this in all my years, on a Super but many times on a Power Major. Must have been a massive lump on the front of the lift with the levers going vertical between the drivers legs. The lower bracket looks like it bolts to the gearbox/rear axle flange. :o
That sounds like a scenario I don't want to have on my tractor as I think it's crowded enough around that area with the shifter already(having thoughts of hacking it off and re-welding it at another angle)... Anyways, I see the difference between the X and Y series and the E1A porting layout but still Pascal manages to use one on his tractor, why? Is he using an adaptor or is there something that will be "lost" when using an X or Y plate? To quote that robot Nr Johnny five: "Input, need input!" :lol:
And another type of valve fitted to a Power Major. Picture from another thread.
Post by Dandy Dave »
This is identical to the one on my Power Major, and it is a DAR valve. :) Dandy Dave!
Ian
Post by Ian »
I been doing a little bit of work on the lift cover before I stick it back on. I noticed one of the O rings on the horizontal pipe had blown out, and the gasket where I've taken it apart had also blown out and was leaking all over the place.
Now my question is .. my tractor has one of those dual auxiliary hydraulics. 2 levers, don't really understand it to be honest.
Anyway the primary one which controls the lift arms, is tapped and the loader is powered off this. In order for the loader to work I think the lift arms need to be raised. Anyway my question is, should i swap them over and tap the oil flow from the 2nd one instead of the first to make it independent from the lift arms ? Can I do this without any problems ?
Foxen
Post by Foxen »
If you are lucky enough to own this piece of "rocking horse manure" equipment, by all means do change that plumbing and start using it :D
If there was a reason for it to be set up like it is now it will probably present itself when you attempt to use it...
Ian
Post by Ian »
It was setup that way because originally we used a hedge trimmer on it and it was connected to the second one. That's all I know about it really.
Kjetil
Post by Kjetil »
Anybody seen this type of valve?
This photo has been shown on this forum before, but I don't remember who put it on.
Kjetil
Roadless63
That is exactly the valve I saw fitted to a super 6 once. It looked like a DAR but still had the flow control and linkage. I never took a photo but its good to know I'm not going mad and such a thing does exist. Thats only the second one I've ever seen!
Maybe Brian has come accross one before?
BearCreek Majors
Post by BearCreek Majors »
I started to get my 63 Super Major back together this week end , this is the DAR valve on it, quite similar to the horizontally mounted valves on the older units. I believe these are for the US market only.
Pat
frode
Re:
Post by frode »
Pascal wrote:This is the hydraulic block on my tractor during the mounting.
It's from a Ford 3000. There a bolt in front to set it on single or dual.
Don't know if it's called DAR?
Did you have to change anything to get it to work, Pascal?
I read som much about different porting and stuff...
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
