tractor mower suitable for lawn
As title sugests , i havewhat you would call a small feild or a big garden, iwould like to use the dexta to mow it and i was wondering if any one could enlighten me on the best type of mower to do this , one that would the grass nice and short . Gerry
Hi Gerry,
try this link: www.caroni.it
Caroni are very reliable mowers available worldwide. I do own one for years that I use with an Iseki TS1610 without any problem. Mine is 150cm, as the Iseki is only 19hp. The Dexta is able to cope with something larger...
Best regards,
Constant
Best regards,
Constant
mower for a tractor
Thanks for your reply constant ,i will have a look at that site i wonder if any one has any other thoughts on this, forgive me for my stupidy but is a topper the same as a lawn mower or does it do the same job . Gerry
Hi Gerry,
A topper is designed to deal with long grass, it generally has a single large blade and leaves a fairly rough finish.
A finishing mower will give a finish similar to a lawn mower, it usually has three smaller blades and leaves a good finish when used on shorter grass. It will not cope very well with long grass.
I have an old Kubota finishing mower, I have extended the lower link hitches outwards because in its original condition it fouled on the wheels on my Dexta, I think that you would have the same problem with other mowers designed for mini tractors.
It can be a bit of a pain using a single cluch Dexta on these mowers as the inertia that builds up in the mower pushes the tractor forward even after you have depressed the clutch. A dual clutch is better or alternatively an over-run clutch can be fitted on the PTO.
There a number of makes of finishing mower available.
Chris
Brailes, UK
"Dexta's rule the World!"
Brailes, UK
mower for a tractor
Thanks for that Chris that is what i needed ,for some one who has used a dexta and knows the pit falls , this will help me before i go out among the dealers and try to buy one. my dexta is a single clutch , but knowing the problem i will know whats in front of me or forgive the pun behind me.
Gerry
set of gang mowers would do a nice job, a set of ransomes mounted ones with pto driven oil pump to drive the blades has its own in and out of gear handle so not having a dual clutch wouldn't be a problem, i used to mow a 10 acre lawn for jcb with a set. if i remember right they were ransomes 214's.
sometimes you need 4!!!
mower for a tractor
Good idea Brian but that kicks up another problem, iwonder would anyone have any idea what would be the best sprayer to use for the job.
Gerry
mower for a tractor
Thanks for your reply dexta 4, the picture tells more than a page ful of awnsers ,that would be the ideal pice of kit, this gives me a lot now to work with , is there such a thing as one the collects the grass or is this just me dreaming again. Gerry
you dont need to collect the grass it chops it very fine and short, the more you mow the better it gets, you'll end up with a finish as good as a garden lawn.
Hello Gerry,
This would be my argument for making a big garden instead of a cow meadow aroud the house.
http://home.att.net/~jmsmith45/50fd.htm
mower for a tractor
Thanks guys for all the replys the pictures on the belly type more and the the rest are great , thanks for them all ,its good to know that the box for grass isnt needed, ill probley go for some sort , of pull behind type as these seem to be the more common type where i am ,ill have to se what comes up . GERRY
mower for a tractor
my dexta is standered s/ clutch non live drive Jos, will this be a big problem for a pull behind mower, how much forward would the tractor be pushed , cm or meters, can this damage the tractor or is it just a hassel, i also wouldnt like to end up buying a mower that i would be wary of useing , , i thought just get a mower for the dexta hook it up and work away
,anyway thanks for your input Jos. Gerry
A lot of mowers have an over run clutch installed as standard but not all.
We have two, one with and one without. If I use the one without on Henrietta, then I have to be very careful as the inertia makes it hard to get out of gear and clutch plus brakes will not stop you quickly. I have developed the knack of whipping the PTO out of gear before I get to the headland but it is not the best. That is why Dotty has now taken over mower duties and with her live clutch she is brilliant!
Nuffy has an independant clutch so again she is good on it.
Over-run Clutch
Hi,Brian wrote:A lot of mowers have an over run clutch installed as standard but not all.
Does mowers include Toppers?
My Dexta has a single clutch, so will I need a topper with an over-run clutch?
Thanks,
I use a heavy single bladed topper on a tractor without live drive. The inertia of the blade will push you several meters forward after the clutch is depressed. Tried knocking the PTO out of gear before I had to stop which was hazardous and cut out the hydraulic lift.
Bought an over run PTO clutch from Malcolm Hipperson for about £40 two years ago - problem solved.. Topper keeps turning.Tractor stops moving
Toppers for Dextas
Thanks for the info.fenhayman wrote:I use a heavy single bladed topper on a tractor without live drive. The inertia of the blade will push you several meters forward after the clutch is depressed. Tried knocking the PTO out of gear before I had to stop which was hazardous and cut out the hydraulic lift.
What type of topper do you have (a pic would be great!!), and is it suitable for a Dexta? How short can you cut the grass with it and is hitting stones etc with a blade topper (as opposed to a flail chain type) a disaster?
I've been advised to get an older, lighter topper as the newer ones tend to have heavy guards etc - any advice appreciated
Thanks again,
Select-O-Speed Dexta?
Great link thanks. Some mowerEmiel wrote:This would be my argument for making a big garden instead of a cow meadow around the house.
Would it be feasible to mate a select-o-speed ('jerkomatic'?) gearbox to a Dexta ?
Al the best,
RM-990
I have a Woods RM-990, which is a 7.5 foot (2.6 meter) finish mower, that is heavy duty enough to use all out with the Dexta and Super Dexta. I has three blade, with stump jumper blades.
I have 5 acres of yard and more than 50 acres of pasture. The Super Dexta handles this mower awesomely.
Wayne
Wayne
Select-o-Speed Dexta
Hey Bendexta, rather than "mate"a select-o-speed gearbox to a Dexta, would it be good enough reason/excuse to buy a 3000-5000 with select-o-speed?
TSG.
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Re: RM-990 3PL Finish Mower
Wayne,WayneB wrote:I have a Woods RM-990, which is a 7.5 foot (2.6 meter) finish mower, that is heavy duty enough to use all out with the Dexta and Super Dexta. I has three blade, with stump jumper blades.
Is this the beasty? http://www.colemanequip.com/Attachment.asp?AID=153 (exc this one has 6 blades?)
All the best,
A local farmer, who has just started a small caravan park.bought a 5 foot teagle finnishing mower with 3 blades last season,
it makes a nice a very neat job with very little mess
the first couple of cuts were hard work for the tractor but once the grass was cut short enough about 1 & 1/4" it is very quick to get a lawn like finish
